I am using HyperMesh version 2026.1, and I sometimes struggle to follow the instructions in the demos. For example, "00-Demo-1-Solution-Guide-GSHM-v2025.1" refers to the Analyze > Structural > Loads > Forces tool on the ribbon.
I cannot find this command, even though all the ribbons are enabled.
Is there a document that helps locate where the version 2025.1 commands are found in version 2026.1?
