i want to implement a custom breakage model that works with MultiSpheres and preferably with GPU as well. It would simply accumulate the principal stresses over time on a MultiSphere particle and after a critical value is reached would randomly select and destash a primary particle in the MultiSphere to simulate breakage.
Is this possible? I would be very glad if someone can point me in the right direction if this is doable in EDEM.
Thanks!
Hi Clemens,
Though you asked for how to implement a custom breakage model I wanted to be sure you were aware of the built-in Tavares Breakage model. Is there a limitation with this model that is unacceptable for your application?
If there is a limitation I can provided you with some suggestions on how to implement your own damage model.
Kind Regards,
Eric
