Hi Altair Community,
In HyperMesh 2025, after using a command/tool and completing the operation, I often need to use the same command again.
Is there any keyboard shortcut that can recall or repeat the last-used command without having to select it again from the ribbon or toolbar?
For example, if I use a meshing or editing command, is there a shortcut key that immediately activates the same command again?
Thanks in advance for your help!
