Hi all,
i have again problem with particles ending up in my mixer geometry. I tried a low timestep (10% of Rayleigh) and have increased the Young's Modulus value to the max 1e14. Still particles go into the mixing tool, which rotates at a velocity of 25 m/s. (~15.000 rpm). I know this value is probably high but shouldn't that be doable nonetheless? I also tested a higher resolution mesh but this seemed to only slow down the calculation.. Also tested double instead of single precision. Nothing helps..
