I'm trying to create an X tube using Sketch and Section Manager with Hypermesh 2025.1, as I did using Hyperbeam few years ago (this time, I have a message "unsupported beam section").
However, I didn't succeed to transform a "geometric" into a "hole" with a solid part (here "ShellPart") inside an other solid part ("Shell Part 2"), when 2 other identical parts are detected as hole.
I tried :
- Remove all other parts, and keep only the "ShellPart" and then, create a circle around : it is detected as an hole.
- use symetries on a top hole, unsucessfully
- Don't use symetries and draw once again the "shell part" : it is not detected as symetry.
I think it is not a trouble from "ShellPart2", because "SolidPart2" is a hole on the center of the sketch.
(in the left bottom corner, I have the same trouble than in the right bottom corner)
Do you have some ideas to do that ?
Thanks,
