After exporting the force data of an object and generating the meta file, I noticed some display abnormalities when opening it. Could you advise on how to fix this?the version number 2026.1;
this is my model
Hi @Jin1 ,
There is an issue where if the force is not set to "Action reaction" that issue persists. So please change the force to "Action reaction". If you have further questions regarding your model, please share it as an Archive Model (File > Export > Model > Archive Model > Zip)
Best,
Christopher Fadanelli
Thank you, I have solved it according to what you said, but what is the principle behind this? Why would choosing Action Only fail?
The behavior is being looked into and will be fixed in upcoming releases.
