The chain sprocket simulation was set to run at 30s.
But after 11s, it had stopped with the error in the attachment.
Is there a solution to overcome this error
Hello @vishnurajanarayanan, can you check the log file of the simulation and see if there were any redundant constrains? The way to overcome this warning and proceed with the simulation is by removing any redundancy. You can share the Inspire model (stmod file) and I could give it a look also myself if you'd like. Best regards, Orestes
