I am running the official example Bend.scm under the hydraulics folder, but it reports an error saying "The Modelica compiler requires Visual C++ compiler version >= 10." I then downloaded Visual Studio 2026 Community and installed the modules as shown in the PDF. However, when I check the Preferences -> Path, the compiler is still not displayed, and even the TCC compiler is missing. How can I resolve this issue?
Bend.scm
Hello @Jin1, I have forwarded this to dev team, and they'll investigate it ASAP. I'll let you know when I have an update. I would suggest thought that you create a support case using Support Center platform in order to better track the case. Hope this helps! Best regards, Orestes
Thank you very much. Feel free to send me any information you have. My Siemens application is still with our corresponding software distributor; she is helping me inquire about some registration-related matters.
