I got this error after I changed the .tir file that is referenced by the Tires entity.
"Illegal index TRAC
Error resolving reference Event Type-value under Model-Tires-Tires-left-Tire Properties. "
I tried to switch back to the default .tir file that was loaded in the template, but the error is persisting. Not sure how do debug this since I cannot find "Event Type" under the Tires system.
For reference, I am using the FSAE Template and following the Shimable Suspension Tutorial.
Thanks!
