Hello, no matter what surface or geometric body I place in CADfeko via a patch array, there's always a 832, and if I try to fix it, I get a 2331, and that can't be resolved. Only the output file shows the triangles, but in CADfeko I have no chance of getting rid of them—no help entry or AI query has worked so far. The example with the dielectric cube and the dipole works. When I try to replicate it with my setup, one of those errors always appears. Pls try my file and then you find the reason that I am doing wrong pls comment. I am out of any glue so far. Thx
