Hi, I am learning how to compute the 2D scattering using MoM with the surface equivalence principle (SEP) and a 1D periodic boundary condition (PBC) in Feko.
I would like to know whether it is possible to construct an infinitely long, z-directed electric line current source located at $(x_s,y_s)$, $\mathbf{J}(\mathbf{r})=I \delta (x-x_s) \delta (y-y_s) \hat{\mathbf{z}}$, to serve as the excitation source. The corresponding incident field is described by the two-dimensional Green's function, $G (\mathbf{r}, \mathbf{r}^{\prime}) =-\frac{j}{4} H_0^{(2)} (k_0 |\mathbf{r}-\mathbf{r}^{\prime}|)$.
If this type of source is supported in Feko, could you please advise how to define it? If not, is there an alternative approach to approximate or realize this excitation in FEKO?
Thank you very much for your time and assistance.
