Hi
how to assign the boundary condition to the rigid body....
tool>BCs Manager in this part option we need to select the rigid component or the actual model component or we need to select both of the component.
Thanks
You can assign boundary conditions and loads to the master (independent) node of the rigid body, so that the same will be applied to the slave nodes connected to the rigid body.
