Nowadays, I try to transfer from 2021 to 2025.
But I'm very confused when I use 'Ruled' in Hypermesh 2025.
I used 'Ruled' when I filled mesh between two components in Hypermesh 2021.
Two components is composed of orphanmesh.
As far as I know, Hypermesh 2025 is operated based on geometry.
So, I created FE Geometry using two seperated mesh component and I tried to use 'Ruled'.
But sometimes, Modifying mesh is occured in original mesh after I conducted 'Ruled'.
It was not my intend. I just want to create new mesh between two component without modifying original mesh.
Of course, I can create new mesh using 'Ruled' without modifying original mesh after deleting surfaces. But it takes a lot of time compare to Hypermesh 2021.
Are there any good method when I create new meshes between two component which is composed of mesh.
Thank you.
