Hi all,
i want to export data from a EDEM run. I use the export -> Results data tab and create 4 queries which contain the diameter and x,y,z positions of my particles. After loading the data into Excel it shows the data for each particle in columns instead of rows. This gives me a headache, since Excel can only import a limited amount of columns, meaning the number of particles is restricted. Is there an easy work-around to this? I have so far not been able to see all the particle data in one Excel sheet.
Thanks!
