I am trying to run FEKO on a server and have two questions :
- Is it possible to run FEKO simulation on a distant server without having FEKO installed there ? For example, a SSH call need FEKO on the distant machine. I was wondering then if there was an option with MPI or so allowing to execute the simulation on a distant machine without having the soft there
- In the case it is not possible, I will try to install FEKO on the distant machine, which runs LINUX. However, the server is a distant machine I can access only through classic SSH from my local machine. How to perform an installation of FEKO without the GUI of LINUX ?
Thanks really much for your help,
Pierre Rodriguez
