Following the training manual, I am trying to create an antenna radiation pattern from the .ava and .aha files in Aman.
As shown in the attached screenshots (I have included both the imported radiation patterns and the patterns generated by the software), the horizontal pattern matches the imported data correctly; however, the vertical pattern is different.
I have also tried switching between linear and logarithmic scales, but the results remain the same. The generated vertical pattern still does not match the imported one.
Could you please advise what I might be doing wrong or if there is an additional setting or step that I may have overlooked?
