Hi everyone,
I encounter an "error creating new process" when importing Abaqus INP files in HyperMesh 2026 on one of our two PCs with identical installation.
The operation screen recording is attached, please advise the repair method.Thank you.
Assuming it works on the other machine? Which should rule out the file itself.
Do any other inp files import ok?
Did you try reinstallation?
I recommend you create a Support Center request for further diagnostics
Thank you for your reply. Exactly, the same INP file imports successfully on my second workstation with identical HyperMesh 2026 installation, so the INP file itself is not corrupted. I have tested multiple different Abaqus INP files on the faulty machine, all trigger the same error "error creating new process". No INP can be imported. Yes, I performed a complete uninstall, cleaned the remaining registry entries and user configuration folders, and then reinstalled HyperMesh. Unfortunately, the error persists. I’ve sent an email regarding this issue to hwsupport.disw@siemens.com already.
You should create a support ticket directly through the Support Center.
Altair Support is Moving to Siemens Support Center! - Altair Community
