Is there any way I can import front and rear suspension data into Carsim? I found out I can create a .par file in MotionView and use it in Carsim, but I didn't find the .par export option in MotionView.
Hi @premkumar_07,
MotionView can interface with Carsim in the following ways:
MotionView allows you to construct suspensions from the Vehicle Dynamics and Suspension MDL libraries that are included with the product. For half-car models, you can select the Kinematics and Compliance task and run the simulation. You can then load the automated reports to visualize the Kinematics and Compliance plots and use the automated MotionView report to create a .par file that can be read into Carsim.
For more on interfacing with Carsim, please see the following link:
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/interfacing/mv_interfacing_with_carsim_r.htm?zoom_highlight=.par
Hope this helps!
Adam Reid
