In my model, the dipole is made of cylindrical PEC/metal parts separated by a small gap. I would like to excite the antenna across this gap and obtain reliable input impedance, current distribution, and radiated power results.
Should I use a discrete/edge port directly between the two cylindrical faces, a small feeding cylinder/bridge with a voltage source, or another type of port/excitation? Also, are there any best practices regarding the mesh around the gap and the interpretation of surface current density when using cylindrical solid/surface geometry instead of wire elements?
