I have a model for a large platform such as Gulfstream aircraft. I have an antenna on the fuselage. I want Claude to keep moving antenna along fuselage. The problem is the antenna coordinates is not in any files that are easily readable text and same for aircraft geometry. Is there any way around it, is there MCP server i can install? i want Claude to optimize antenna location on the aircraft. What are AI capabilities that are available that can be used with FEKO?
