Hi, I inserted a Python Glyph in nCode DesignLife 2026 (Windows 11). The correct Python version (3.14.0) and NumPy are installed, and the environment variables are set correctly. However, when I run the process or compile a simple dummy script, I get the error shown below. Does anyone have any clue what the problem might be and how it can be solved? Thank you!
Message : <class 'ModuleNotFoundError'> No module named 'glyphscriptScripting122428'
- Import 'glyphscriptScripting122428' failed. (file size=5)
Code : 0xfff5fed0 = decimal -655664
00000 Memory
00001 Load 63%
00002 16066MB total
00003 5914MB available
00004 27330MB total (page file)
00005 14070MB available (page file)
00006 134217727MB total (virtual)
00007 134211597MB available (virtual)
000080000900010 System Info
00011 Processors 8
00012 Processor Architecture 9
00013 Page Size 4096
00014 Processor Type 8664
00015 Allocation Granularity 65536
00016 Processor Level 6
00017 Processor Revision 21767
000180001900020 OS Version Info
00021 Major Version 6
00022 Minor Version 2
00023 Build Number 9200
00024 Platform ID 2
000250002600027 HW Profile Info
00028 Dock Info 1
000290003000031 File System
00032 No data available
000330003400035 Data Manager
00036 0 entries - cache allocated 2147483648 bytes
0003700038 Remapping enabled : TRUE
00039 Verify records : Off
00040 Verify streams : Off
00041 Verify storages : Off
00042 Verify files : Off
00043000440004500046 S3 File Manager
00047 filename=c:\Users\mmang\AppData\Local\Temp\nc_global_dummy_T[00005968]_G[dc542491-49eb-42b0-a288-d8f56ca94ba5].tmp, pFile=Ox04DB6560, thread=Ox5968, ptr=Ox00000000, readwrite
000480004900050 Application
00051 Workspace : WS1
00052 Delete data on the fly enabled (global) : TRUE
00053 Delete data on the fly (this) : TRUE
00054 Glyphs that can switch pipe states : 0
00055 Glyphs that can request skip cancellation : 0
00056 Pipe states backed up : FALSE
00057 Repeating : FALSE
00058 Run : 0
00059 Run count : 1
00060 Run error count : 0
00061 Run complete : FALSE
00062 Run skipped : FALSE
00063 Ranks are stored : FALSE = 0
00064 Resetting : FALSE
00065 Stepping : FALSE
00066 Running : FALSE
00067 Paused : FALSE
00068 Stopped : TRUE
00069 Interactive : FALSE
00070 Complete : FALSE
00071 Reset : FALSE
00072 Break : FALSE
00073 Next File : FALSE
00074 Running to glyph : FALSE
00075 Preparing to run : FALSE
00076 Stop pending : FALSE
00077 Waiting for next single step : FALSE
00078 Auto collate : FALSE
00079 Collate OFF : TRUE
00080 Collate GATHER : FALSE
00081 Collate REVIEW : FALSE
00082 Collate results available : FALSE
00083 Logging : FALSE
00084 Use shared scratch file : FALSE
00085 Looping : FALSE
00086 Has looped : FALSE
0008700088000890009000091 Global journal entries
00092 Out : 09-Jun-2026 07:49:35 Run started00093 Error : 09-Jun-2026 07:49:35 <class 'ModuleNotFoundError'> No module named 'glyphscriptScripting122428'
- Import 'glyphscriptScripting122428' failed. (file size=5) Scripting1
