Hello all,
i have an issue with my storage drive. We are running a lot of simulation with PSIM. Our internal storage cloud is configure to perform continuous back up. The waveform output file (.SMV file) weights a lot. The problem is that our back up system is doing continuos back up of avery .SMV file at any simulation. The backup has been set to prevent data lost in case of failure in our network. The multiple backup are filling up our cloud system. I would like to know if there is a possibility to configure the PSIM with different path for only .SMV file. My intention is to direct only .SMV file in my local PC drive.
Thank you guys
Technix
