Hi, I'm simulating the steering force and boost force when the car is stationary and simulating steering according to a sinusoidal event. The results show that the steering force when stationary is smaller than when the car is moving according to a sinusoidal event, whereas it should be larger.
I'm wondering where I'm going wrong? Could it be due to incorrect tire modeling? I'm using the MF Swift model for both cases.
I used a vehicle model from the library and ran a sinusoidal steering event with all parameters kept at their default values.
For the stationary steering case, I exported the steering angle profile from the sinusoidal steering event and used it as a motion input through a curve. I deactivated the Altair Driver and set the Differential torque and Brake torque/force to zero. The vehicle remained stationary during this simulation.
Any insights would be greatly appreciated. Thanks in advance!!
I also posted a similar comment here. I apologize if it has caused any inconvenience or annoyance, but I honestly don't know how to delete the comment "https://community.altair.com/discussion/comment/201154?utm_source=community-share#Comment_201154"
