I'm having some issues performing a free size optimisation on a monocoque I'm designing in my spare time.
I have made a working laminate structure using Hyperlaminate, this effectively places my laminate directly into the PCOMPP Property card, which is perfect when performing a simple analysis. However when I got around to performing a free size optimisation, there was no laminate within the model window to select. So after following: Optimisation —> Free Size —> Create —> Laminate, because the laminate was directly placed into PCOMPP there wasn't a laminate to optimise. Do I need to make the laminate in the model window with all the steps that go along with that process, or can I export the Laminate created in Hyperlaminate into the model window to select it? in the picture below. The picture showing the absence of a laminate.
Thank you in advance
James
