i wanted to make sure my setup for AR and S11 optimization of microstrip antenna is proper.
I want to optimize my structure by optimizing 2 parameters, my goals are set as:
S11 less than 15dB
AR<3dB RHCP
Hi @GKO ,
I'd say that looks good.
Best regards, Torben
Of course, the global goal doesn't match the actual goals in terms of numerical values, if you have multiple goals. It's calculated based on the individual goals. Unfortunately, the individual goals can't be displayed. But you can still see the actual result if you plot it on a separate graph (not the goal, but s11 or Gain).
Hello Torben,
Thanks for the answer, i have a followup question, is it normal for global goal to have values this high and even negative values? Optimization setup same as in the screenshots i attached)
