Description:
I would like to display values such as forces and SPCs in HyperMesh 2025.1 in the same way as in version 2021.1.
I would also like to display nodes where mass is assigned.
In addition, I would like to enlarge mass elements and the triangular markers that indicate the positions of SPCs.
Could you please explain how to do these settings?
Product/Topic Name : HyperMesh 2025.1
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
model example of 2025.1
model example of 2021.1
