Hello, I am validating the geometry for a double wishbone Baja SAE front suspension. After reviewing the results from the SDF file (KnC ride, roll and steering), I am having trouble interpreting the results. At 0s it shows an Anti-dive % of -13.46, the design value was intended to be 25%; the Anti-lift result seems to be more in line, showing -22.47%. Which one of the 2 results should I be looking if I have outboard brakes and what does the negative simbol mean? NOTE: I am using the baja/fsae libraries and MotionSolve 2025.0
