I'm looking to plot S-Parameters for the purpose of extracting capacitance values throughout a frequency sweep. I am able to run the simulation, plot S-parameters and export the SnP file, but here are the issues:
- Either the capacitance is about twice what it should be, or
- this shunt capacitor electrically looks like a series inductor
My setup is very simple:
- One outer cylindrical shell with ID = 6.00 inches, wall thickness = 0.125 inches and width = 8.00 inches
- One solid cylindrical inner conductor with OD = 5.00 inches, width = 7.50 inches.
- primitive cylinder surrounding all geometry with about 8 inches of padding
I assign "air" (dielectric that I created) to the larger encompassing primitive cylinder, and the other two bodies are perfect electrical conductors. I added two lines, each starting on the inner conductor and ending one the outer conductor—one on each side of the capacitor. I union all solid bodies and lines, then assign wire ports to each line and put the "location" in the middle of the lines.
Next, i request S-params and specify both ports as active, provide a frequency range to sweep and run.
I'm not sure what I could be doing wrong here, so if someone could please take a look at my setup, I would appreciate it. The calculated capacitance for this geometry should come out around 60 pF, but I am getting 180 pF.
I've uploaded the .cfx file.
Thank you,
Daniel Perk
