What is the reason for this error when I use the bonding v2 model and how to solve it? Thank you.
hi, it's difficult to say from the image.
In general I would recommend making sure you have the latest GPU drivers installed, it's best to install them directly from the Nvidia Site and ensure it's the correct drivers for the GPU card.
Also best to use the latest version of EDEM. Which version of EDEM is this?
If you have the latest updates it maybe running out of memory. EDEM particles typcially take 1-2 kb of memory per particle, if it's a large simulation and the GPU doesn't have much memory then it could be running out of memory. What card is been used and how many particles do you have?
Regards
Stephen
