Hello
My distributed coupling reference node and weight is not being exported when using Hypermesh 2026. Please help.
Can you please give more details or share the model?
Can you share an image of the setup?
My IT wont let me send files/images thru this forum. Can you email me? Or provide your email?
please see attached
Here is the example model.
Thanks jason
then how do you apply constraints on a DCOUP3D? I had no issues exporting a distributed coupling in the past. I just started using 2026 version and now im having this issue.
you can set this on creation or on editing after the fact
Why cant I do that with *Distributing? I really dont want to use DCOUP3D?
Is that option available in Abaqus?
Yes, but even with that option it still wont doesnt export the reference node and weights.
