I have successfully optimized the structure; however, I am struggling to generate a functional geometry from the results. Before I attempt to manually reconstruct the NURBS, do you have any suggestions? My primary issue is shrinkage at the fixed interfaces, and the resulting NURBS surface is often non-manifold or open-edged. I have experimented with various mesh-processing tools, but I haven't achieved a viable solution yet. I'd like to obtain the results in https://help.altair.com/inspire/en_us/topics/inspire/structure/fit_polynurbs_c.htm,with intersect. For context my part is 400mm high and of a diameter of 150mm, the common dimension of a fixed geometry is 8mm
