Seam Weld in SimSolid
Altair Forum User
I cannot create a weld for the structure as shown below with SimSolid 2020.
I tried with SeamWeld options but couldn't find the weld between the curved face and flatten face.
Can you show me how to created weld as below image?
Attached file is my model.
Thank you!
You may try weld from lines(feature lines), if there are any in that region.
Otherwise, these are not supported. you might have to explicitly create a solid weld in such cases.
0 -
Hi Girish,
Thanks for your support.
I tried to create weld from lines and solid but it still failed.
You have any ideas for other weld for this case?
Thanks!
