I need to model screws in inserts with a RBE2-CBUSH-RBE2 type connection. The goal is to be able to use the connectors tool and not do it by hand, because I need to model that type of connection in a model where there are several dozens or hundreds of screws. It seems the connectors tool does not work when the holes don't go through all the parts.
I have attached an example.hm file that mimicks what I need to do : there is a rectangular block with 4 inserts in it, and a rectangular plate just in front of it. The plate is modelled using shell elements and the block using tetra elements. (The tetra elements are needed in my final model because the geometry will be way more complex that the one from my current example). Therefore the holes in the plate obviously go through the whole thickness, but not the ones in the block. I tried using the connectors tool with the right tolerance and other parameters (I think), but it is only able to create the RBE2s on the plate side, not inside the inserts' holes…
- Is it possible to use this tool to do what I want to do, or do I have to model the screws by hand ?
- If it is possible, what do I need to change for it to work ?
Thanks for your help !
