When I do a simulation calculation for both filling and solidification, I would expect that the solidification starts with the temperature distribution of the filling simulation. I have the idea that that is not the case. Is that right?
Hello @Erka100 ,
Yes, when you do simulation with filling and solidification. The temperature of solidification starts from the end of filling. If that is not the case, that could be a bug in older version. If you are using older version of Inspire Cast, I suggest you use the latest version.
