I can't import geometry to Altair MotionView. Tried direct importing the geometry in STEP, Solidworks, Parasolid, STL and even Hypermesh formats, however, still can't import it. No error message is displayed when importing, nor at the message center. Also no error logs are generated.
Also tried importing through "Geometry or FEM using Hypermesh", which results in importing the bodies but no graphics. Hypermesh and Inspire can import the models succesfully, but not MotionView.
Tried a full clean reinstall of all Altair softwares, tried a clean windows install, tried turning off the antivirus.
What I'm trying to import is a simple assembly of a 4 bar mecanism from Solidworks to MotionView. Also tried importing a simple singular CAD instead of a assembly and still the problem persists.
MotionView works fine using Baja/FSAE template available to download from Altair official tutorials. I've had run several multi body simulations from the templates. All the others softwares are working fine, the only problem is importing geometry.
Altair Student Licence
Windows 10
Norton Antivirus
