what is the value of displacement in intermediate exam for hypermesh in final quiz, im not getting it correctly
We cannot tell you the answers of the examination quiz. Kindly follow the instructions in the exercise document carefully and you will surely get the correct result. I have just completed the analysis again and getting the proper result. Are you facing any problem in the analysis set up? Let us know the difficulty you are facing. Thank you.
Dear sir,
we will not be able to verify our results if the value range is not mentioned anywhere. I have followed each and every step many times again and again and i feel my answer is not correct (submarine hull)
