Hello. I am trying to model the coupling between two wires running parallel on Feko v2025.1. I have been following the EMI/EMC learning series using Altair Feko Example 1-3 YouTube series, as well as EMI/EMC learning series using Altair Feko Example 4 Shielded Cable Crosstalk, as best I can. But for most of the model's life I have not been able to add a current source no matter what I've tried, and recently can no longer even add a voltage source. Can I please have some guidance as to what I'm doing wrong?
I've also got a lot of errors I cannot even begin to debug…
Hi @BigFluffyDuck ,
Can you share the model here ?
Shannon Mistry
Hi @Shannon_Mistry the model has been attached. Thank you for your time!
The model needed to have a device ground before connecting it to the installation. I have added it to the model, please check. The model also was missing the source and destination pins for "offending cable". I have added that too.
I also added a 100 MHz frequency to run test run. Please change it to the required frequency later.
Hope this helps. Let me know if you have any questions.
Shannon
