Dear Professor, I am a beginner in using EDEM.I have a few questions regarding the Bonding V2 model.
1.I am trying to set up the Bonding V2 model, but no bonds have been generated. Below are my relevant parameter settings and the simulation model. Could you please help me identify any issues with my setup?The failure to bond may be related to the timing issue described in my second question regarding the Bonding V2 model activation.
2. For the Bonding V2 model, can the settings only be applied before particle generation? If I configure the Bonding V2 model after the particles have already been generated, will the bonds fail to form?
3.Is the Bonding V2 model suitable for studying brittle materials with high hardness?
4.I would like to carry out a secondary development based on the Bonding V2 model. The approach is that the bond strength degrades as the local temperature of the material increases. Is this approach feasible?
Thank you for your guidance!
