I have a two question regarding FEKO.
1. As I understood, FEKO uses two different material modeling : Metallic and Dielectric. Metallic modeling can be applied to surface. So, I need to make region as free space and apply metallic model for Faces. Dielectric for solid or closed surfaces. But, I want to use solid model for metal as well. but the system doesn't allow. In this case, I can manually make metallic material by using dielectric material tap(For example, by putting very large value for relative permittivity)
2. 2nd question is regarding I should I manage the boundary when metallic & dielectric material share the faces. As far as I try with simple example only 1 material is allowed for the 1 faces.
