I performed a simulation of lifting a plate using two cylinders. When the plate was modeled as a Rigid Body, the results showed that force appeared only in one cylinder, and its magnitude was nearly twice the force obtained in the flexible-body case. Therefore, I chose the flexible-body model because it provides a more reasonable load distribution between the two cylinders. However, in the flexible-body simulation, although both cylinders carry force, the force directions at the joints are inclined relative to the cylinder axis. Could you please explain why, in the rigid-body case, the forces at the joints remain aligned with the cylinder axis, whereas in the flexible-body case the force directions become inclined?
Many thanks!!!
