Hi all,
Is there an easy way to extract the instantaneous longitudinal ground friction coefficient (Mu vs Time Step) from my Fiala Tire model?
I'm aware that Longitudinal Slip is already an available output, and thus, I could do some post-processing to derive Mu from the Mu_Slip_curve. However, this could lead to user errors if the post-processing Mu_Slip_curve is not the same as the one used in the simulation.
For context, this is for a Landing Gear drop test simulation.
Thank you!
