I am currently using the 2026.0.2 version of AI Hub.
To upgrade to an environment that supports GPUs, I followed the instructions on the following page: https://docs.rapidminer.com/latest/hub/install/docker-compose/deep-learning.html
I have completed the installation up to nvidia-docker2.
However, the version shown in the environment file example under Instructions (Altair AI Hub) is too old (9.9.0), and I do not understand which parts of my existing .env and docker-compose.yml files need to be modified.
I anticipate that GPU usage will be essential for future text and image analysis. I would appreciate it if you could provide guidance on the installation and necessary modifications.
