How can we evaluate or verify the heat transfer coefficient between the casting part and mold components in Inspire Cast, such as the permanent mold and core?
Hello @Huyen ,
You can check the material properties through material viewer window and verify the values. You can even edit those values to create your own material card and use it for the simulation. This can be done for cast part, Mold, core, etc..
There is a value for HTC at mold metal interface based on a coating selected. You can also check which one to be used for your need.
Add/Edit Mold
