Hi, I need to create a glued contact between shell and a solid components to do a modal analysis in NASTRAN (the equivalent would be a Freeze contact in Optistruct).
Can someone help me on how to create these contacts?
You can use the 'contact browser' in HM and then right click and use auto-contact.
Hi, I need to create a glued contact between shell and a solid components to do a modal analysis in NASTRAN (the equivalent would be a Freeze contact in Optistruct). Can someone help me on how to create these contacts?
I believe there is a TIE contact in NASTRAN ...
