발급받은 학생용 라이선스 키 입력 후 activate 누르면 이런 오류가 뜨는데 해결 방법이 무엇인가요
Hi @young1230
The message license already exists in license store means the activation is already successful,
You could go to the location of the license in the license store, this is the path in the activation tab under the license store field, delete the .lic file there and then reactivate,
Please share screenshots of the error you see if the issue persists.
Thanks
