Hello everyone,
I'm a begineer so probably this could be a stupid question!
I created the mesh and now I should do a quality check to fix some bad elements. Unfortunately, when I open the qualityindex panel I get this by default:
instead of:
I thought it is related to a wrong threshold option (2.0 probably is too much, but they have both same values and I imposed the same element size before meshing). How should be the correct values if this could be the problem?
Thank you so much!
