Hello everyone,
I'm a beginner using Hypermesh, so probably it's a stupid issue but here we go!
I have to check the mesh quality of a component. Unfortunately, when I open the qualityindex panel, by default the component appears all in red as the following image:
Opening another model, it appears correctly as I wish, so I can easily visualize in yellow or red all those critical element:
As you can see all threshold parameters are the same, the display thresholds aswell, but checking the %failed it's different, so I assume it's something concerns this, but how can I fix it?
Thank you so much!
