Hello, how are you?
I'm encountering a bug with the export results option. I have a configuration with multiple queries, which when exported shows 0 values for one of the variables. But, if I a use second configuration just to export this query, it shows the data.
What can be causing this? It's troublesome as I'm using the export configuration for a set of simulation.
Thank you.
