As the subject implies, I am trying to make a tapered pipe (a common task for me). I know I can setup circles on a rail and do a sweep, but hoping there might be a simpler way….
Dear Dhalpin, I am attaching a video showing how to create the same in Inspire quickly with creating reference planes at perp to centerline endpoints.
I hope this helps. Thanks.
This is exactly what I needed. Thank you very much, Saurabh!
Hi Dhalpin, I am attaching a video showing either using two circles or using draft. Please check and let us know if this helps.
Thanks.
Thank you Saurabh. I should have been more clear - the pipe is not straight. I would like to import the centerline curve and have Inspire place circles at the endpoints (perp to centerline) so I can run DOE on the circle diameters. I could not find a way to draw on a plane perp to centerline endpoints.
