Hello everyone,
I would like to simulate a platform sliding on the ground supported by two wheels. Initially, I tried using the contact , but it was not effective, so I replaced it with the impact function
When I disable Joint 6, the results are as expected: after the platform tilts, it slides along the desired road profile.
However, this is not realistic because Joint 6 exists in the actual mechanism. When I enable Joint 6, the platform penetrates into the ground. Could anyone please advise me on how to fix this issue?
I have attached the archive file for your reference.
Thank you very much.
